Heads are back, just took pump and injectors in...
93fordturbo
La Crosse, Wi
Heads look good, cleaned up nice. Took pump in and getting it rebuilt and should push 90cc's of fuel and governor set at 4k, fueling until about 3600 rpms. We will see how that goes. Should I have him advance the timing curve? Or should he do that automatically?
93fordturbo
La Crosse, Wi
I took it to a local pump shop, very reputable. La Crosse diesel. Was also wondering what stock turbo pump flow is
Whatever the srock setting is its too low.. We need more fuel...:sly Go big or stay on the porch...:angel:
93fordturbo
La Crosse, Wi
Should I tell him I want 100cc? I just figured I would try to stick with the junior moose flow. Will my truck handle 100cc pretty decent?
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Bull Moose - 102CC
Moose Junior - 90CC
Baby Moose - 75CC
The Baby Moose is a high quality build of a stock spec'ed pump. Everybody has a different need but I'd go right for the Bull Moose.
:sly
oregon96psd
Kuna, ID
Bull Moose - 102CC
Moose Junior - 90CC
Baby Moose - 75CC
:sly
that cant be right can it? A stock pump flows 90-100 cc's, and the hotrod moose pump flows 102?
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
valves would be the least of my worries at those speeds. although floated valves are no walk in the park either as far as damage goes. it is still better than a hole in the block.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I would think the valves might "float" at those high rpm's. However, I could be wrong.
Based on the videos that have been posted in the past of people running these engines up to 4K+ RPM's, yes, the valves will float unless you put in stronger springs.
I've said it before, and I will say it again...unless you've done some work to the valvetrain and to the bottom end to make the engine stronger, you are playing with fire.
