I am guessing that this procedure is not going to help in your case anyway. I think (could be wrong on this) Mel is talking about greasing the shaft where the bearing slides, to free up it's movement. The sound you are hearing is most likely the bearing failing and I don't believe they are open and greasable (but like I said, I could be wrong) I know my bearing is a sealed bearing and while you can and I have greased the shaft it slides on, the bearing itself is non-serviceable, but that is my truck, yours could be different. I have seen many throwout bearings start a kind of chirping sound. I had an S10 that did that, I changed the throwout cause it drove me nuts, and within a couple of thousand miles it started chirping again and continued to do so when I sold it some 75,000 miles later to my dad, who then sold it with another 50,000 or so on it without a throwout bearing failure.
