FPR shimming
DBogo
Upstate NY
is there any downside to doing this will it shorten engine life or shorten the life of anything and what does it do more power more smoke what is it exactally
jlayne
Bondo Bandito
Milledgeville, GA
from what i've read it just raises the fuel pressure to ensure the injectors get a full load... helps in atomization so it makes the engine more efficient.. i have heard people say it adds HP. and MPG and reduces fuel crackle in the late model trucks
maybe somebody a little more educated in FPR shimming will come along and clean up my explanation but i think i got it pretty accurate
they say 65-70psi is where most of them like it... but every truck is different, i plan on doing this mod after i get my fuel pressure gauge installed
kwazyca
HALF A BUBBLE OFF?
Redding, CA
jlayne has it right. 2 years no problems for me. I run in the 65# range.
Ramprat
Inside your OODA
I've got an upsidedown bassackwards shim & installed it in summer of 98 ifin I remember right (but it could be summer of 99) & it started out over 100psi & think I ended up around 65 psi.
No extra noticable black smoke till I did the SCMT thing.
No problems at all with the upsidedown bassackwards shim :D :D :D
jlayne
Bondo Bandito
Milledgeville, GA
if you know somebody that has a new edge evolution put it on your truck for a minute... the new programs they have out are wicked!!!
the new programs 80hp setting will smoke my old evolutions 100hp, it also has much much much better low end power
i'm sending mine off this week to get upgraded with new software
Dzlnut
You can get the california regulator kit from ford if you don't want to messaround with the guess work. I don't recall the number but they can look it up under the cali trucks.
Stevo
geonc
SPIDER BAIT
NECKVILLE North Carolina
About the only negetive thing I have heard about shimming the FPR in high mileage/orig fuel pumps is the OCCASIONAL report of F/P seal failure.
Seems higher mileage pumps cannot handle the press loads.
BoyerCustomTruck
Anybody have the part numbers for the spring that goes in there? mines broke. If the california kit has a spring in it, that would do also...
Thanks in advance
kwazyca
HALF A BUBBLE OFF?
Redding, CA
Thanks in advance
What year is your truck???
JU57US
