MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
I spent some time under my hood with a tape-measure and short ruler.
1985 Ford diesel w-A/C big huge factory radiator.
Height of finned area between top and bottom tanks = 23-3/4"
Width from outside edges of mounting flanges = 33-3/4"
Now, herein lies the dilemna :
Instead of the shorter V-8 I-H, there resides a lengthy inline six-cylinder sandwiched between the firewall and radiator.
With clutch-fan removed, pretty much centered with the radiator, is the clutch-fan mounting "stub"; there is only THREE-INCHES between the radiator and this stub.
There is 3-3/4" clearance from such things as the water-pump, belt-tensioner, Leece-Neville, etc.
I would love to install dual 3.8-L Taurus fans, or a worthy equivalent.
Can someone provide me with an overall thickness measurement of the Taurus fan ?? the same for the dual fans of a Windstar ??
If there is so much as a molecule that protudes too far, it is a no go.
I have been considering the possibility of re-working the radiator mounting and somehow moving the radiator forward a couple inches; I know a vast amount of cutting/notching/reinforcing would be in order.
I have also seriously considered installing the radiator in front of the existing grille, leaving the A/C condensor as is, and fabricating a custom grille to protect/conceal the radiator; doing thus would alleviate my lack of real-estate in the easiest manner, but I worry what it might do to A/C condensor performance.
I need some THIN fans.
Thanks
Thanks
