>>> THE FAN SAGA <<<
I am gonna step out on a half-sawed limb and say this :
It is likely that I haul and work my engine as hard as any here.
Other than poor A/C performance, I have never ever had any cooling issues.
The thermostat is a 180* unit and the gauge settles at 180* and stays there, up hill and down, sitting in heavy traffic on HOT pavement, or climbing MontEagle with fifteen big cows.
And it does that with a
sick wimpy never really engaged wore-out anemic lethargic coast-a-long
useless piece of
clutch-fan that I bet I could hold still with my hand when the engine was running full-tilt.
I bet a fat lady with a paste-board funeral-home fan could push more air across the radiator.
I locked/pinned my summertime clutches strictly in an attempt to draw some air across the condensor, not at all on account of engine heat.
I bet I could toss the mechanical fan, hang on a set of the wimpiest electric fans, and do just as well.
Since I started this thread, I have found a
secret weapon
that I had been searching for for a long time; I knew they had to be available somewhere;
a genuine direct-drive fan hub.
I put the order in the mail Thursday for the hub and matching all-steel high-RPM fan.
When it arrives and gets installed, the next step is a segmented aluminum shroud.
Then, even if I have to (and the way it's looking most likely will) hang the grille on a nail in the barn, I am gonna mount the strongest pusher-fan I can find in front of the A/C condensor.
As I have limited space between the radiator and engine, any decent electric puller-fan is just too big.
So, I will let the direct-drive fan do the heavy work; and, when the RPMs are down to nothing, the constant speed of the pusher-fan can do it's thing for the condensor.
The
is afixin' to hit the
