ok well since speedo dont work and stock gauges suck im doing custom gauges now. i need to pass inspection somehow.
so that lead me to get a gps speedo what do you think of this one,
http://www.speedhut.com/custom_gauge_description-gauge_type-Speedometer_GPS-auto_number-914.htm
and this i hopewill be the fuel gauge,
http://www.speedhut.com/custom_gauge_description-gauge_type-Fuel_Level-auto_number-601.htm
in the dash i will have speedo, tach, oil psi, volts, and water temp,
then i already have pyro, boost, tranny temp, and an alt voltage gauge mounted elsewhere.
i think that should cover everything ill need gauge wise.
now to pick up the 2 inch hole saw.
