With a heavy load on behind my truck(20,000 GCWR+) I start to get lots of turbo flutter/surge around the 14-15 psi range, the boost guage starts to float around(it does this empty also,) and it never goes past, even when I manage to bring those boost levels up below 3000 rpm, I have seen 18psi before, but, that was with -40 ambient temperatures. I'm going to expirement here shortly and turn the pump up some more, I have a feeling that with how the compressor side of the turbo is sized, 15 is about all it's good for, more is too far beyond the CFM it's efficent at moving(off the map if you remember the twin turbo thread where I explained sizing.)
I have a feeling that adding more fuel is just going to make more smoke, and not more boost. I may be wrong, but, I'm pretty certain that I'm at the limit for this turbo as it sits.
