ATS 093 + Boost Gauge
ninjai
Canada
Turbo newbie here, where would I connect a boost gauge to my 1990 7.3 w/ an ATS 093 turbo? I read in another thread about an 088 that you connect it to the pressure chamber or something. Is that correct? If so, I have the chart of part numbers and stuff for my turbo in a PDF and it says it's #3 on the diagram. Is that where I would connect the gauge somehow? Is it like a plug or something?
Thanks.
PDF:
http://www.atsdiesel.com/additionalinfo/2023056/7.3L Ford Wastegated Turbo System Layout v1.0.pdf
jam0o0
houston, tx
on part #3 remove part #44 and screw the sensor in there. be sure to use thread sealant. not teflon tape.
subway
be nice to the admin :D
York PA
nailed it, right on the intake snail there is a little 1/8 pipe plug.
ninjai
Canada
Good to know :). Now once I get my new a-pillar and boost gauge I can start toying with my turbo some more... :backoff
ninjai
Canada
So I took a pic of my turbo. I'm not positive which wire is for monitoring the EGT, but I think I saw one *way* down the exhaust... like a foot or 2 past the downpipe, and then there's the one that is clearly attached just before the turbo.. but not sure what that port is for. Any ideas? I'll trace it closer next chance I get when I'm free.
subway
York PA
you are not going to see it in that picture. the pyro probe is going to be located in the exhaist system itself. sounds like it might be mounted on your downpipe after the turbo, better than nothing but a more accurate reading is putting it right in the exhaust manifold itself. after turbo you have to add a couple hundred degrees to compensate for the heat loss through the system.
ninjai
Canada
Okay, thanks. Might sound like an odd question, but.. any idea where the stock pyro wire is mounted on a '97 powerstroke? Is it far down like mine is or right after the turbo?
ninjai
Canada
And u might want to check your air cleaner
My filter? It's the K&N one that comes with the turbo, it basically reached that level probably a month after I cleaned it. I think I actually need to replace it since the rubber around the filter is so old it's starting to crack :S
Dieselcrawler
Professional wrench holder
Quakertown Pa
Any parts store carry the filter for the factory setup. Just tell them it is a 93 7.3 turbid f350
ninjai
Canada
Whoa, K&N are crappy? So... the other one is 'better'? More air flow?
Also tighten the oil elbow a little to move the oil line farther from the hot housing.
The PO may have put the pyro probe in the turbo inlet flange, Mine had a tapped hole there.
Lance
Staff online
