I spent the better part of the other day installing my ARP head studs, cleaning out the holes and using a bottom tap to get them as perfect as I could. Soooooo as I was installing my nicely bulit heads that I got back from the shop yesterday with new pre cups and comp 910-16 springs and my expensive A$$ gasket set using the arp ultra lube and set the studs in the head afer I got them down, screwed them till they touched the bottom and lubed up the washers and nuts. First pass 40 ft-lbs no problem second pass 80 ft-lbs no problem. Took a break and came back third pass 125 ft-lbs one side done went to the other side and got halfway through and heard a loud SNAP and the stud went loose went to tighten it down and it just spun, pulled the bolt and ran a swab and found thread parts in the hole . So now I am going to buy a helicoil set 1/2-13x1inch rated at 220,000 psi and a long drill bit 33/64x12inch to fix the 6 holes that are bad using the head as a guide. Has this happened to anyone else or am I just the bad luck king. (I called ARP and told them my situation and the guy said in 16 years he never heard of this happening)
