U joints could cause it but it’s hard to say until we get some new shocks on the truck, which will happen after final ride height is figured... so that’s going onto back burner for now.
Made some good progress today, I started on the gauges, spent a good amount of time massaging the gauge pod with the bench grinder till it fit flush and clean.
For those who don’t know, this is meant for an obs truck sense it isn’t available for bricknose and older.
I used two sheet metal screws to hold the gauge pod where I want it, I like where they are located but I’m going to use a different screw that sits more flush than these.
The pyrometer was an older model so I replaced the stock bulb with an Led I had leftover from another project, now it matches the rest.
Soldered all the conections and grounded everything on one of the screws, that way there’s just one power coming in, two sensor wires and the tubing for the boost gauge, makes it much cleaner.
