I was comparing to Oldbull. The F350 are single piston?
No the eldorado calipers areI was comparing to Oldbull. The F350 are single piston?
Glad they are good for something.Problem solved. 7.3 IDI head bolt to the rescue!You must be registered for see images attach
The power steering works great. One finger even with the 37s, and the steering is super tight and has no play now
Yep just a stock pump resealed, I’ll post the part number for the kit when I get back to the shop. I’d check to see if your fluid is getting real hot after driving in town, could have a restriction somewhere. I bet you’ve already done this but greasing ball joints and tie rods can help with stiff steering as well
Took the truck into town today, went to get an alignment and the tires balanced, turns out it wont fit on a regular rack so I'm going to do a tape measure alignment here and take it to a big rig shop if it needs it. Tires balanced out nicely but still has a vibration at 35-40 mph and vibrates after going over a bump or bridge at highway speeds.
