Custom instrument cluster build
ROCK HARVEY
Dayton OH
I’ve been kicking around the idea of a custom gauge cluster for a couple years, and I decided recently to go ahead and attempt it. I learned some things along the way, so I thought I’d make a post to help anyone else wanting to tackle this project.
My reason for doing this is that the flexible circuit board on the back of my instrument cluster separated and failed. I ran a separate wire to get my fuel gauge working, but that and the Speedo were all I had. When my Speedo gauge failed as well, I decided enough was enough. I started by tracing the shape of the opening onto some 1/4” plexiglass, and cutting out circles of various gauge face sizes to see what I could fit:
I ended up with an 85mm GPS speedometer and tachometer, a 2” fuel level gauge, and space for three 1.5” gauges. I went with oil pressure, engine temp, and fuel pressure. Most the gauges are cheap ones from Amazon. I also added separate idiot lights for oil pressure, temp, and fuel pressure. I bought indicators for the parking brake and high beams, but skipped the seat belt warning light. I have a separate EGT gauge that is rectangular and sits in the cubby by the “wait to start” light. The truck is non-turbo, so I didn’t need to fit in a boost gauge. I made the holes in the plexiglass using hole saws in my drill press, very carefully lol. I painted the plexiglass black, and did major surgery on the housing and epoxied the part I needed to the back of the plexiglass. At this point things were looking good:
Notice at this point that I also had to cut away the vertical trim pieces in the bezel/housing. I was able to shave them very close using a sharp chisel, and then sand the remnants down flush. After sanding everything with 400 grit the housing looks like it came from the factory like that. I bought pre-wired sockets for the 8 lights below the cluster, and was lucky that they fit snugly in the holes in the housing. Now for the fun part:
I labeled all the wires in the truck harness, and wired up and labeled the gauge side as well. Some things to note here:
- there is a 500 ohm resistor in the battery warning light circuit. You need to include this in the new wiring as well, because the alternator relies on either the charge light bulb or this resistor to excite the alternator. I drove around for a week with no cluster and my batteries started to die.
- Aftermarket tachs need a signal from the stator on the alternator to run
- To make an idiot light for oil pressure, I bought an “oil sentry” pressure switch for a kohler lawn mower engine. It closes the circuit when the pressure drops below 5 psi.
Next came time to test for the new cluster, and I ran into a major issue. There was not enough space behind the cluster for my new, deeper gauges. I had to cut away most of the plastic behind the cluster in the dash, but even that didn’t give me enough because the air vent is right behind it. I had to cut about 1/2” off of the threaded posts on the back of my tachometer, leaving just enough thread for the mounting nuts and washers. Thankfully after this I got it to mount up. Finally, I decided to make a new plexiglass cover for the cluster since the factory one has a hole in it to press the trip reset on the odometer. I heated up a sheet of 1/16” plexiglass and carefully bent it to get the curve, then cut it to shape on my bandsaw.
ROCK HARVEY
Dayton OH
Finally, I put everything back together. The finished product is looking great!
I have a few odds and ends to tie up still. I haven’t connected the hose for the fuel pressure gauge, and I bought a voltage meter / USB charging port that I’m going to put where the ash tray is now. I also realized during testing that I accidentally switched the 4x4 light and the low range light. But overall I’m really happy with the look, and it’s great to know how fast I’m going!
ROCK HARVEY
Dayton OH
A couple things I forgot to add:
- my truck is an 89. Other generations might have different issues with fitment.
- I used two 12-pin DT-style connectors to connect the cluster wiring to the truck wiring.
- If you buy the same Amazon speedometer and fuel gauge I did, the white backlight is really more of a blue. I’m swapping the other illumination lights to 8k LEDs to match them better.
-Speaking of illumination, I carefully made a hole in the fuel pressure gauge housing and epoxied an LED into it to make it light up.
- I know people will bring up the fact that I used a mechanical fuel pressure gauge inside the cab, but I personally think it’s fine in a diesel. I would never do it in a gas vehicle!
ROCK HARVEY
Dayton OH
How much do you think have in parts ?
Speedometer: $61 https://a.co/d/jj2tilT
Tachometer: $38 https://a.co/d/9L8xc99
Fuel level gauge: $21
Auto gage 3 gauge set: $102
Fuel pressure gauge: $13
indicator set w/high beam and brake lights: $10 https://a.co/d/1QqS3sf
Small LEDs for idiot lights: $6 https://a.co/d/fbNrCWn
Replacement LEDs for dash lights: $10 https://a.co/d/8b1IyoN
LED sockets: $6 https://a.co/d/2HaAU0P
1/4” plexiglass: $18 https://a.co/d/1BmjZ96
1/16” plexiglass: $15 https://a.co/d/65ixx6T
DT connectors: $16 https://a.co/d/bnSdk47
Voltage meter/USB &12v outlet: $16 https://a.co/d/c6cJhUs
I also used a good number of heat shrink crimp connectors and heat shrink tubing, plus epoxy and spray paint. I estimate another $20 for those miscellaneous supplies would bring the total to $352. I do think I had to buy a hole saw for one of the gauges, but we all know tools don’t count since they pay for themselves eventually :-D
kbenz
kannapolis, NC
thought about doing this in my 93. mine is pretty beat up with tabs glued back on or missing
ritchey
