I think it's pretty close but mine had studs in the firewall instead. Actually I'll post a picture of it later to compare.
I was thinking if you're going the other way, a '92-up master (or full kit) into a '91-down truck, and if the cylinder rotates within the firewall flange, you could turn it so it's straight up and down.I used the master from my 88 in my 94 and it cocked it counter clockwise looking from the front. So I'm sure it'd be easy to fix. I had to knock the studs out of the firewall and drill out the holes to make it fit. It had to be a quick fix but I'll end up using my old master which is still good. At the time I couldn't deal with the time it'd take to bleed it.
Not that I can find. Go on RockAuto, dial up say a '95, and you see several masters, several slaves and several full kits. Pull up '85 and all you see are masters and slaves. I would think if anyone had a full kit for the earlier years, they would. Nothing at LMC or the Graveyard either; haven't checked NPD.Are new master/slave assemblies not available for your year?
This went from an obvious clutch master/slave issue to scrapping the vehicle. If you couldn't figure out the clutch issue, then old vehicles are not for you.
Heck, just getting into a new to you old vehicle can be expensive. For me, my old cars all have lifetime warranties for most parts, so its mostly free. I have no reason or desire to buy a new vehicle.
Some of the guys here have been following along since I got the truck just a few months ago. The clutch issue is hardly some major issue that I can't handle. It, along with the sudden down pour of fuel all over the place, is just a number of things that have been signs that a line has to be drawn somewhere. You see I didn't mind at first, but go read back, luck was always against me with this truck. I have 13k+ into it now, add on the fact i've been in a rental for over a month of the three or four? months i've owned the truck. That's why people were ragging on me in the other thread about driving it with bad steering...I didn't know because i never actually get to drive it under it's own power. I can't name two consequitive weeks that i've had it in my possesion. I went this route thinking it would be better than a payment..But this truck itself was a bad egg. Not the generation of them. If I knew than what I know now, i'd rather have dumped 15k as a down payment on something. It would have been a heck of a lot cheaper and worth while than stripping the truck to the frame and replacing every part. I really think that's what it would take to get this thing reliable. If I ever need to go out of town, I get a rental anyways, I just can't trust this truck that it will get me there and back
I guess so. I knew it would not be a turnkey truck when I got it. So i didn't mind paying for the jasper, i wanted to be ahead of the game and replace the biggest part of it with something that was supposed to be reliable. As most of you seen, my luck was against me and it's been pretty discouraging. Now with probably needing new fuel lines, it's just nearing the edge of when is enough enough? I suppose it may be wise to pick up some beater car to keep around. But i think if I did that, i would just tear this truck down and start over with it instead of waiting for something to break once a week.
As disappointed as I am with it right now, I suppose I will keep positive and see what comes of it. I'm ordering the terrapin plate from mel tomorrow and will give it a go.
Now, what were y'all saying about the newer master cylinders? The terrapin plates are going to have the bolt holes on an angle..i imagine tipping my style on an angle isn't going to work out.
I recomend u thoroughly read my how too..before asking me questions on what I recomend cause the answer is in the how to I linked originally for you! read it n re read it......Thanks for that. I'm going to be ordering a new MC anyways to be on the safe side, I noticed the boot is torn and a little seepage so no sense in taking chances. Just wanted to see which I should be ordering. Now, some of us (eh hem) were lucky enough to have everything already bare under the dash...Having done the install, would you reccomend I take all the pedals out or am i going to screw something up and be better off just banging my knuckles around in there?
I'm going to have to shop for something fun to make me appreciate this thing again. Maybe some new wheels or an air freshner or something lol. I think i would be better off swapping the odometer for an hour meter...it's spent more time stuck in one spot than he has actually driving around.
Then ask questions
I can tell you didnt...u may have looked at pics but not read it.....lol
just sayin....
Al
Adjustable pushrod would fix that real quick.When you built your bracket to mount the master to did you by chance space the master off the firewall too far into the engine compartment so now the clutch pedal doesn't push the rod into the master far enough to actuate the clutch?
