Catbird - did you have to modify the newer door panel to work with the bricknose dash? I thought they would interfere. But ive never tried a set yet.
Mike.
I'd try to find factory doors. Much heavier and i think you will be happier. Sturdyness is my concern. Not the fit.
The driver side fit without issue however passenger side near the top, and just under & forward of wing contacted the dash. I taped two or three ply's of cardboard to the end of dash, then used a heat gun to "heat-up / soften" the contact area on door panel, then closed the door and allowed it to cool. Worked great and is now "form fit" to my dash. There was also some minor electrical / wiring mods because the OBS power window plug is different than Brick. The colors do not match however nobody has ever mentioned it. 1987 cab & center console (originally red), 1989 dash, 1995 doors & rear set, 2005 bucket seats, headliner & carpet are aftermarket.Obs rear side windows.
