94.5 f350 7.3 psd wont start. Looking for pcm in houston area
I thought so too, until I pulled the bolt and saw it wasn't.
A bad pcm wont exactly cause low hpo.
Dallas kovach
Well it's not sending enough voltage to the ipr and so you think I should take it off and screw it back on?
greenskeeper
PA
Unfortunately I don't. And yes I have tried cranking with icp unplugged. I do know that it wont build above 200psi oil pressure but brand new hpop,lines,icp,ipr,idm,cps, a bunch of pig tails and other things too I can't think of right now
How are you determining 200psi of hpo ?
Dallas kovach
I still think it sounds like wiring.
In your opinion what else should I check before I buy a pcm? Could it possibly be the harness connector to the pcm? I cleaned it with electronic cleaner and dried it out about a week ago but there was no change
greenskeeper
PA
Really need a scan tool or torquepro app to see what the PCM is trying to do compare to what is actually being logged
greenskeeper
PA
I have PC based version of autoenginuity and like it's interface and that it can read almost every vehicle out there. It has paid for itself at least 10x over.
https://www.autoenginuity.com/products/scantool/
I have heard of people using the torquepro app with a bluetooth adapter to connect to the diagnostic port....a lot cheaper but I have not personally used it.
Dallas kovach
On the GB reman website is a pinout and resistance check for the harness.
What is the Gb reman site? And yeah at the shop they told me they looked over the harness connector for the idm and pcm and Main wiring harness in engine bay and to the ipr also but it doesnt hurt to check for myself.
It looks like they don't have one for the main harness anymore.
Basically you would ohm from the pcm end to the ipr.
Dallas kovach
Do you know what the ohms should be on the power wire coming from pcm going to ipr?
Lance
