Chubbs090
Diesel-holic
ok heres the scoop. i have a nice 79 f150 camper special supercab. the 351m i have in it isn't what i really want. i have a 7.3l idi out of an 89 f350. how much trouble am i getting into with this.
???????Not that much, the IDI is very easy compaired to newer diesels.
its a 250 frame everything but the axles are heavy duty but will it bolt up to the stock c6?
"Camper special" has heavier rear springs, a transmission cooler, and a bigger radiator. Also a larger alternator and trailer wiring. Engine choice was was FE or 460, or later 351M 400 or 460.
http://cgi.ebay.com/1973-Ford-F350-...oryZ1319QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The 9" should handle a NA IDI just fine. After all they are a favorite of drag racers puting down more power than that. The 9" just can't handle a lot of axle weight since it's a semi float axle.
