Higher piston/bearing speed is bad when you add boost. It also shortens the time the piston stays parked at TDC...
Why do you mill the tops of the pistons, is it to get compression down, or ?
Trying to learn.
Thanks in advance.
Will
Milling the piston tops is a two fold thing. All, and I really mean all 6.9 and 7.3 idi motors have the pistons coming up out of the cylinders as much as 31 thousands. Thats just how they are designed. Now knowing that think about the flat cylinder heads... What keeps the pistons from hitting the heads.... Gnomes... Not really but its the thickness of the head gaskets. I know Felpro gaskets are around 74 thousands thick before being compressed. After that they are around 71 or 72 thousands. They a mls gaskets so they don't compress much. So knowing this you see why its so important to know how much your pistons stick up out of the cylinders. My first rebuild they were between 47 & 54 thoudands. Way too much. When that motor burned down every piston showed a mark from the valves. It was seen but I couldn't measure it. I tried and found it almost a painted look from the vavles. No damage was done... Yet. When you mill the block like I did the distance from the crank center line decreases and the pistons are higher up in the cylinders by that amount. My block lost about 8 thousands because the shop messed up big time. So my new set of pistons are the low comp (the pin is machined 10 thousands higher in the piston) and still I needed to take off around 12 thousands to make them fit where I was comfortable at 24 to 26 thousands above the block surface. Even then my compression is 530 lbs with about 8 thousand miles on the motor. So things will get better. I talked to an engineer at Mahle about milling the piston tops. The recommend no more than around 15 thousands because then the top ring is that much closer to the heat and flame front. Sure, you can mill plenty off because the tops are around .580 thick. Thats almost 5/8 inch. These are the informations I have found. What some do outside of this is at best experimental but thats how we find out what works and what does not.... After I milled my pistons I had a ceramic coating applied to the tops called CBX from Tech Line. They know their stuff about coatings and offer plenty of options and help.
I've never rebuilt an engine, nor dabled in engine design, so the following is nothing other than an attempt to learn.
Explain to me how having a shorter connecting rod changes the piston dwell time OR piston or bearing speed. My guts tell me both of those are controlled by the crank. I would think the piston speed would remain the same, as would the dwell time.
To my understanding, what you are saying is partially right, a shorter rod will move off of TDC quicker but there is no reason that it should create any bearing or ring problems. after all it is still turning the same RPM and it dosen't change anything other than where the rings ride and the CR
