I would like to start by saying that I have scoured this site and FTE for this problem, but I have not found anything like it yet.
Difficult to explain, but when I attempt to shift into 4 High ( I have the manual shift lever) it just shifts past it... it doesn't set into 4 Hi if that makes sense. I have to just pull lightly out of 2wd while holding the lever and wiggle it back and forth slightly while looking for the dash light to come on. It doesn't actually engage the 4 Hi even if I get the light on, but that is another issue. Basically, it just doesn't settle into gear. The truck has a 4" lift and an auto to manual tranny swap (Previous owner). Just as an aside here, it does engage into 4 Lo normally.
Any experience with this?
Managed to limp it to an off ramp that actually had civilization (by more or less pushing as hard I could on the t-case shifter while trying to drive) but had to ask a friend to come get me and spend most of my 4 day weekend running around trying to find a replacement case and get it on.
