LCAM-01XA
None of my links are that short, but then again none of them, is from a truck with the stupid push-down shifter. So I guess I'll be of now help there, sorry! What you can do is measure it yourself - put the transfer case in 2wd and the shifter all the way forward till it bottoms out and measure distance from bushing pin to bushing pin, then move transfer case to 4x4 low range and shifter all the way back till it bottoms out and measure again, finally transfer case goes in 4x4 high range and shifter also in 4H but held right against the gate and measure again. Should come up with three very close if not identical measurements, post here what they are.
