kcw12
CrazedCountryRebel
Well sorta.
symptoms: Loud Clunk sound. Loud Gearish sound When in wheel drive high i can rotate the front drivesaft about 3/4 a turn, then it catches the rear one for about 1/4, it will try to turn it, then slip and go again. Loud gearish sounds, you know the ones that arent good even if your on the other side of Neptune. Gets louder when you lock it in 4 wheel drive. gets really loud when in 4L.
I think its the transfer case. has one else seen this. I called Towcat on it and he too thinks it the transfer case. Any input is welcome
