Picking up where I left off.
Here is the lever for the seat.
And seat installed.
Probably going to have to trim it. Door closes but I think it will hit the door pocket.
It works.
I checked the travel. Seat won't hit the windshield. Spring is weak enough the seat has to be held forward or it just slides back. Turned out pretty good I think.
On to the next thing. Pulled these out of the filler necks. These were a really stupid idea. No wonder you can't get fuel in these tanks.
This is my solution.
1/2" hose vent to the tank to the neck. I'll cut the hose to length once I set the bed on. Did the front one too.
Bought new bed hardware. Dorman kit for the superdutys.
Looks decent. I think they will work.
Also got battery hold downs.
Need to trim the studs off but it was a quick fix. Not sure I'm going to get lids done but I think that will make it road legal. Still have to do the one under the cab.
Front leaf spring clamps finally done.
Got clamps on all the pipes.
That's a pile of clamps. I painted the core support where I cut through for the core support. Bunch of other little things. Early night tonight relatively speaking.
