viscosity improvers DO NOT make oil thikcer as it heats up. They just prevent it from getting as thin as it owuld without the viscosity imporvers. They make it act like a heavier oil without viscosity improvers would act at a high temp.
another example viscosity measure 1-10 10 being lightest thinnest oil 1 being thickest
regular oil cold is 3 hot is 8
oil w/viscosity improvers cold 3 hot 6
heavy oil no viscosity improver cold 1 hot 6
so the viscosity improvers make your lighter oil act like a heavier oil at high temps while retaining lighter oil charecteristics col.
That's what they do. It doesn't thicken the oil at high temps it just prevents itfrom thining out as much as it would normally. clear?
Thank you for putting this in terms folks can understand,So many people have gone on BITOG and have filled their heads with all kinds of gobbelty **** that they think they are experts on oil and it drives me nuts.
You are correct a 15w-40 oil is NOT a 40, but in fact it is a 15 wt oil, with the film strength of a 40 wt at operating temp, but in no way is it as thick as a 40 wt at operating temp, The 40 wt rating has to do with it's ability to keep internal parts separated from each other , it has nothing to do with a thickness test.
In the same way, a 5w-30 is not a 30 wt, but it is in fact a 5 wt oil with the film strength of a 30 wt at operating temp, which is yet another reason I've been against their usage in this size engine except in extreme arctic conditions, it's simply too light an oil
A 15w-40 starts out heavy when cold but thins out when at operating temp. A 5w-30 starts out fairly thick at cold and gets almost watery feeling at operating temp. A 0w-20 or 0w-30 will start out fairly fluid and get slicker than snot at operating temp
If you are going to try to burn any of this stuff in your fuel tank it is going to behave about the same, but keep in mind when you start mixing viscosity grades and brands , funny things can start happening in the chemistry when you get that many different brands going, that's a lot of different additive bases mixing trying to do their thing, but all in all it should thin down as it heats up.
