troupp
ok, I switched pumps because my old one was bleeding profusely out the weep hole, I thought I'd use the max fuel allen screw as my tdc locator for switching the pumps, not realizing that it'd have 2-3 tooth play while the allen key is installed in the hole. Dumby me didn't make any back-up marks. I've advanced the new pump to the end of it's travel, and it still isn't right, as compared to the other pump's previous running ability. Both pumps have been on this truck before, and both have their own pump-mount/gear housing. So I know it isn't right just because I had to change the pump timing from when it was previously installed then removed.
Anyway, on to the real question: If I pick my ip gear housing back up which way does the gear have to go to advance my pump timing one tooth. This thing needs to be back up and running asap. Is it clockwise or counter clockwise as facing the motor?
HELP!!!!
HELP!!!!
