troupp
Ok, let me make everyone aware that I am NOT an idiot. I am an ASE certified master tech, that can see the obvious. The truck runs. It is very sluggish compared to how it did run, egts are way high way quicker.. this suggests its off a tooth, which it was. For most people, removing the housing would be dumb, as they do not already have another pump, housing and gear already attached. I've switched this twice before, but like was said before, I made much better marks between the 2 pumps to ensure it didn't get messed up. This time I thought the allen keyway would be accurate enough until I saw first hand how much play it had, by then it was too late. As Mel said for most people, it would be worthless for them to remove the housing just to fight the pump/gear bolts on the floor, where while mounted in the truck, the gear remains stationary to remove said bolts.
I thank everyone for their help, and semi-constructive criticizism. But, when I swtich my pump again after getting a reman one, or moose pump, I'll probably switch it just as I did this time, because The other housing has no corrosion build up on it, and I need to do a valley gasket at the same time. so I might as well make everything as clean and accessable as possible.
