What size of battery cables
Slydinclyde2
Peculiar Mo
What size cable do you guys run from battery to battery and to the starter? Got the truck home today and the battery's were flat dead may have a drain on them somewhere. GP controller maybe. The cable look like hell. Any battery preference brand and size? I know only like 3 company's make batteries with different quality control for the higher end batteries.
I have double 0 gauge wire in my truck.
im also running some group 31's
she never has an issue turning over!
Slydinclyde2
Peculiar Mo
Did you have any fitmet issues with the 31 series? Found some at a tractor supply store for $100 a piece 970 cca
The grounds run to the bottom of the front part of the engine block right above the oil pan.
Slydinclyde2
Peculiar Mo
I saw that's were they are currently just figured cut down on som resistance by mounting one to one of the starter mounting bolts.
ifrythings
BC
If I remember right stock grounds are 1/0, batt to starter is 3/0 and batt to batt is 1/0 I believe, I'm going 4/0 for everything.
lotzagoodstuff
Carmel, IN
Group 31's fit fine in a bricknose, but not in an OBS. If you fill out your signature and tell us what truck you have it will make it easier for folks to answer some of your questions.
Matt_INW
Washington
I have custom batt mounts, #1 under the hood, #2 on the frame under the pass front seat.
ive seen group 31's installed in the stock location.
I have lots of grounds. lol
double awt on grounds as well.
2 main grounds from battery to the engine.
#1 bat also ground to the core support.
a ground going from engine to frame.
8 ga grounds from core support to frame
from frame to cab
from engine to cab
from heater core to cab
from radiator to frame.
overkill. yup
