Hey everyone!
I'm under two weeks out do my 3rd Ontario to BC road trip in "Moonmud" '86 6.9 Camper Van. Been at it last month trying to replace and upgrade as much as possible for the smooth journey this time...
Here's my recent REPAIRS;
- Warrantied / new Group 34/78 850 CCA batteries
- Battery / Starter cables - 4/0 to starter, 2/0 everywhere else, 6 gauge for battery to relay / extra grounds (Thanks @franklin2)
- Grote Military battery terminals
- Pulled wire harness to engine bay, re did any "road trip" repairs from previous years, clean connections, harness taped, and split loomed.
- #2 gauge alternator cables with MRBF fuse bolted to the 78 side terminal post, very nice location.
-25' #2 gauge DC-DC charger cable from starter battery (fused on other 78 terminal post)
-All new V-belts (Fleet Runner Heavy Duty Green)
- Vacuum pump 11/32 hose (was rubbing a hole on alternator)
- Heater hose and top radiator hose (will do full flush and bottom hose in spring)
- Electric oil pressure gauge
- Hall-sensor ammeter for glow-plug dash amp gauge!
MODS
- Inline electric fuel pump used for priming (still having over night drain back issues I can't seem to find) - 3 seconds with the pump and system is primed for startup every time.
NEXT STEPS -
GLOW PLUGS
- Currently - Manual push button to fender relay, new 2x10awg wire harness to spade connectors, ZD-28 plugs. Ammeter Dash Gauge (120amps cold - 80amps hot after 10 seconds)
Tested the plugs last week, during overhaul all read 0.7ohms, after a -15C startup, 3 died! SO now have to replace, but having bad luck with ZD-28 plugs on push button… like 3 sets now in a year…
Option A - Try 80034 Glow-plugs on current manual glow plug setup with dash ammeter. @Black dawg @Old Goat
Option B - Install 7.3 controller onto fender wall (I have a salvaged one from a wreck) and splice harness to take ZD-29 bullet style connectors, and swap to ZD-29. Keeping manual override on the controller a possibility.
Option A, if the Bosch plugs are reliable, seems like the easier / cheaper option. $8 CAD rockauto special. Keeps old spade connectors for now and don't have to pull out my harness again.
Option B, well I would be trusting the salvaged 7.3 controller, finding a spot on my vans fender to install, splice in aftermarket bullet connectors onto harness. However may never need manual button again?
Great to get anyones input on Glow plugs, my recent repairs, and anything you can think I can should look into before I leave for my 2 month road trip!
Thanks!
MODS
NEXT STEPS -
GLOW PLUGS
Thanks!
