InnovativeAV
So I've had a pretty good knock upfront when I'm in four-wheel-drive and I let off the gas. I had a bad spindle bearings so we ordered a kit from Dana. I have a Dana 50 upfront right now. After doing a U joint and some other things we found out that the carrier gear is shot inside the pumpkin. Right now I currently have 4.10 gears. I plow with the truck so I think I'm going to do a Dana 60 solid front axle swap. And I'm thinking while I'm at it I may go down to 3.55 or whatever gears I can find. And I may just put a 1 ton axle in the back saying that my yoke bearings are shot. I do run the highway once in a while so it would be nice to get rid of the 4.10. I'll keep everything updated if I decide to start doing a swap has anyone else done a swap like this and what should I look for being involved?
