Turbo cleaner spray?
BC4Lyphe
United States
I got some turbo wash liquid with my boat. It's made in Japan, I've got a Yanmar engine. Stuffs like $80 a gallon. Anyways I guess you just put it in a squirt bottle and shoot X fluid ounces into the turbo, under load, over a period of Y seconds. Anyone used something similar on their 6.0? Kind of thinking I should clean the vanes but would rather not take it apart.
DaveBen
Ukiah, Ca
Drive it like you stole it! That is how I clean mine. Never had a problem in 13 years.
X2....
Don't baby a 6.0....... they don't like that..... I normally get after it on an on ramp..... or from a light when the person in the little sports car thinks they are fast....... LOL
In some of the other countries that are primarily diesel, it's pretty common.
Not so much in the U.S., except some vw diesel guys do it.
SebastIDIan
NW Georgia
Get it up to operating temps before you start playing and as said before make sure she gets a good workout.
bismic1
Texas
The only way to clean the turbo's turbine wheel inlet guide vanes is to take it apart.
I believe the cleaner you are talking about is to clean the compressor wheel blades.
Supposedly they will clean the vgt side.
Now on a 4 banger, that may work. But something like a v8 diesel, you would almost have to feed it a garden hose. Lol
I agree to take it apart.
Didn't ford have a pcm update that would actuate the unison ring at idle to help keep it from sticking?
bismic1
Texas
Definitely not arguing, but very curious - How would it clean the exhaust side after going through the pistons? I am assuming it is a fuel additive then .... maybe mistaken there?
The thread below is what people typically think of when discussing "washing the turbo blades". It is a water and detergent wash of the air compressor wheel blades introduced with the air intake.
http://www.shamrockboatownersclub.com/forums/threads/cleaning-a-turbo-charger-on-a-yanmar-6lp.35019/
The vgt vanes are directing the flow of exhaust gas across the turbine wheel.
As I said, it would take a lot.
But basically you would need a steam out the exhaust.
bismic1
Texas
Hmm, sounds like a smart plan to steam out something that can rust and stick.
BC4Lyphe
United States
Yea I heard about the unison ring getting carboned up so I like to let her eat a few times on short trips and pass the little ricers good n fast on highway trips. Thats why I didnt think it was the unison ring. Is the PCM update what makes it sound like a jet at high idle? I ended up unplugging the EBP sensor and it stopped the turbo bark and power cutting out. Any idea on how/why the EBP tube gets caked up?
bismic1
Texas
Since Jasper didn't answer your question .......... lol
Probably many things can plug the EBP, but poor combustion is a common cause.
Injector issues, EGR issues, turbo issues, etc., even tuning can cause excess carbon. Biased sensors also, like IAT2, MAP, etc.
I like to watch fuel economy as a rough indication of combustion efficiency. I also watch EBP, MAP, and Baro at KOEO to verify they all read the same.
As far as the unison ring goes, carbon and rust are common issues. At least a stainless unison ring can help w/ the rust.
You would think nothing would actually be able to travel up the tube, being the end is capped off with a sensor.
"Turbocharger vane sweep strategy - Performs a sweep of the turbocharger vanes and unison ring during stationary idle conditions. Vane sweep can occur once per hour to help reduce turbocharger sticking."
lewisstevey7
