Apr 7, 2019 #1 Ray-F250 Registered User Joined Feb 11, 2019 Posts 36 Reaction score 21 Location Georgia hey fella s I cut my truck off and now it just clicking at the Selenoid any thoughts it was running just fine
Apr 7, 2019 #2 79jasper Chickenhawk Joined Oct 13, 2012 Posts 17,367 Reaction score 1,930 Location Collinsville, Oklahoma Well, did you replace the "solenoid?" Sent from my SM-N960U using Tapatalk
Apr 7, 2019 #3 Clb Another old truck Supporting Member Joined Mar 1, 2013 Posts 5,757 Reaction score 2,240 Location nannyfornia Elaborate! More info will help . Start by filling in your Truck stats in sig line... In no order... Battery Key Starter Cables Grounds
Apr 7, 2019 #4 chillman88 Supporting Member Supporting Member Joined Feb 22, 2017 Posts 6,027 Reaction score 6,156 Location Central NY First thing I would try is jumpering the two large terminals on the solenoid together (with the key turned on). If it cranks it's a bad solenoid.
Apr 7, 2019 #5 Dirtleg Full Access Member Joined Aug 11, 2007 Posts 1,319 Reaction score 577 Location Cloverdale VA Will it crank if you jump over the solenoid contacts with a screwdriver or wrench? If so and as you say solenoid clicks when you try to crank it replace the solenoid. It not check your grounds and power wire to the starter.
Apr 8, 2019 #6 Ray-F250 Registered User Joined Feb 11, 2019 Posts 36 Reaction score 21 Location Georgia It will not crank by jumping the solenoid I have a battery cable terminal that is cracked I tried to jump it off but nothing I’m going to replace ter
