WEll, I am 'fugin, but I am not really happy.
When I got my PA Biodiesel centrifuge, I noticed some red oil in the inlet port and inside the fuge. I assumed this was a testing fluid. Now I am not so sure.
I attached a video of m basic system, it took me forever to get the fuge to run.
Started my pump up, primed it with the system in bypass mode. slowly began closing the valve....very slowly........
Nothing, no noise no vibration, just WMO flowing through the fuge and the bypass line.
I start thinking to myself, maybe my pump is too small or motor too slow or pulleys wrong.
So I took the fuge apart, and here is what I saw.
I never paid any attention to the inside of the fuge when I got it and never took the bowl apart, but after it wouldnt run, I took it all apart, and the lower O ring on the bowl was pushed out, and the hole that feeds oil to the bowl is partially exposed. PLus, there is some stuff flaking off the bottom of the fuge bowl.
If I put the system into by pass, and slowly, I mean take like 3-4 minutes to close the bypass, I can get the fuge to spin. I cannot close the by pass 100% or the O ring will spit out. The top of the bowl moved up and give the O ring enough clearance to spit out.
http://s30.photobucket.com/albums/c341/ntolerance/?action=view¤t=VID-20120908-00000.mp4
