GRU
fear the chicken legs
so is missy a bit upset the "good vibrations" are gone??
So just why wont you buy a new truck... Your being pushed in that direction. Go for it..... Drive it to dinner or church on sundays. Use it as a backup to the idi rigs... Wouldn't that just be the cats ass doing that...
That's the plan. I just talked with Brain at SBC. He would like me to "reposition" the pressure plate 180 from where it was and see if that fixes the problem (it won't). If it doesn't, he will sent me a new flywheel, pressure plate, disk, and TOB. Basically, a new SMF kit.
I just had the trans out before this started and fortunately, the bearings were great, but I did put 2000 miles on the truck with it vibrating. Hope everything else is OK.
Heath
The request to reposition it 180* is a curious statement. I worked in a trans shop years ago for a little while. On the only clutch job that I did there, we went through 4 clutches and pressure plates before getting one that didn't vibrate. I never thought about reclocking the pressure plate nor did the owner.
If they drill the presure plate and clutch at the same time, that might explain it.
I agree with all the above. If the holes are drilled off center, it will be off center reguardless of the oreintation of the pressure plate. These pressure plates don't have dowel pins to help with alignment. Some pressure plates do. Secondary to this, if you aren't careful you can get the pressure plate slightly off center, but not to the degree with off center mounting bolts.My feeling is that if you have to reclock it it is junk.
Even today Gary, she told me to buy THIS TRUCK...... if I sell the '86 crew cab. I said it's nice, but I'll keep my IDI crew cab.Oh... Your going straight to hell Heath for that comment...So just why wont you buy a new truck... Your being pushed in that direction. Go for it..... Drive it to dinner or church on sundays. Use it as a backup to the idi rigs... Wouldn't that just be the cats ass doing that...
Its ok....I agree with all the above. If the holes are drilled off center, it will be off center reguardless of the oreintation of the pressure plate. These pressure plates don't have dowel pins to help with alignment. Some pressure plates do. Secondary to this, if you aren't careful you can get the pressure plate slightly off center, but not to the degree with off center mounting bolts.
Heath
Stand strong Doc! Them new ones can break down too and ya may not be able to fit the needed tool in the to box like ya can with the IDI's.
But then again if you can change a wheel bearing race with a claw hammer and a ratchet......![]()
