91 F250 7.3 diesel XLT Toboggan ( worst snow truck I"ve ever owned )
OK people I collected a pile of parts and its time to start dismantling stuff, question of the day is "if I don't want to take the coolant system apart what wrench would I use to get at that last bolt on the injector pump. I'm thinking offset open end basic hand tool but mine got stolen a while ago and dam if it isn't impossible to find one of those. 9/16 angled open end wrench is apparently a thing o the past and Found on Road Dead doesn't list a special tool for that application.
I could take the coolant system off but I'd still be staring at how to tune the pump once its all back together, so I might as well find the right wrench now rather than later. Any ideas, maybe a crows foot but those got stolen as well and I'm thinking there's not enough room in there to get the shaft past the IP housing anyway.
on another note my alternator seems to have some damage on it. The square plug in is pretty much melted off. Blue wire is completely gone and the other is barely hanging on. Going to need a new connector as well as either repair or replace the alternator. I'm surprised it was even working with wires not even connected and all. Looks like an overload of some kind must have occurred, anyone seen that damage before and know of the likely cause. I'm not into simply replacing stuff without at least trying to figure out what went wrong in the first place
also wiring harnesses, I think I might have asked before but I keep finding things wrong with this harness set and would really just prefer to replace it while I have the whole thing apart anyway. Any sources would be greatly appreciated. Or sources for the connectors, I could build my own if I just had the connectors.
just for grins I thought I'd try and get these headers on without taking off the fenders. I'll keep you posted on that process. I'm trying to dismantle as little as possible. I did remove the fender wells so I could get at the bolts from an easier angle. Might work, might not. Just thought I"d try.
thanks folks, I'm sure I'll have a few more questions before its all back together
Injector actually looks pretty easy with everything except that one bolt coming out nice and easy. Haven't removed the injectors yet but once I get that last bolt off the IP I'll be well on the way.
Getting kinda long winded but if anyone knows the right wrench to undo that last bolt off the IP I'd sure appreciate the tip
cheers
B
cheers
B
