Garbage_Mechan
Garbage Mechanic
Going through Tousley Ford parts on line it looks like most of the orings and seals unique to the 94 turbo set up are discontinued. Any alternatives?
the olives are the same as the fuel lines.
turbo hat to manifold, i use carb to air cleaner gaskets.
valley pan gasket, and CDR gaskets Russ will have.
where in CA are you?
foothills? oakland?
i have a bunch of that stuff, if need be
I have 100 oem drain grommets on hand. FYI
Hoarder ;p
