Sourcing gaskets / seals for 94 turbo IDI turbo set up
ironworker40
NYC Ironworker
nj
What gaskets are you looking for? A couple of members here can help you but be more specific.
Going through Tousley Ford parts on line it looks like most of the orings and seals unique to the 94 turbo set up are discontinued. Any alternatives?
No 1 gasket now in production am I aware of as being turbo specific...just grommets
Gaskets nope
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Specifically I was looking for all the gaskets and orings to transfer the turbo system to another engine. I'm thinking turbo oil drain grommet, CDR to VC grommet, turbo to Y exhaust gasket, Intake hat to turbo outlet oring, turbo hat to intake manifold gasket, and turbo oil supply line olives.
the olives are the same as the fuel lines.
turbo hat to manifold, i use carb to air cleaner gaskets.
valley pan gasket, and CDR gaskets Russ will have.
where in CA are you?
foothills? oakland?
i have a bunch of that stuff, if need be
Garbage_Mechan
Garbage Mechanic
foothills? oakland?
I live in the foothills not to far from Yosemite, but I spend 5 days and 4 nights a week in San Jose. 101 and Oakland Rd.
The orings and olives are generic, just have to track down. The CDR to VC grommet isn't a big deal, likely will not pull the CDR off of the VC. Just concerned about the turbo oil drainback to valley grommet. Kind of hard to get to that one later.....
Thanks for the offer to help out much appreciated!
ironworker40
NYC Ironworker
nj
As stated @typ4 and also agnem at conestoga diesel has all turbo and intake hat gaskets, I'm not sure if they have the CDR grommet, but it can be bought at any international dealer if they don't have them
1813229C1 car grommet IH calls it a hose
1805319c1 CDR valve
I have everything you need. I have 100 oem drain grommets on hand. FYI
m2rtin
