Well that's one that I haven't heard of before.
Yes.is that fahrenheit or centigrade..?
This is exciting! I'm totally gonna try paint and body on KITT one day.I'm not a auto painter but today I am .
Time for primer.You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
Well darn it. I guess it's not Kelvin or Rankine.Yes.
Turbo 7.3@KansasIDI i can’t remember what you did? Is it in your build thread?
Dropped a turbo 7.3 in place of the 6.9?
And what did you do for priming? A grid heater....?
Seems backwards, with LOWER compressionTurbo 7.3
Hypermax turbo with Wicked Wheel 2
Glowplugs deleted, replaced with short 10x1.0 mm plugs, CDD head gaskets, for lower compression.
Higher psi injectors from Russ
Turbo spec IP from Moose diesel
Return rails and ARP studs from R&D
It’s in my thread, but I need to update it. I should’ve taken more pictures.
I’m so syked, this truck seems entirely different.
Tranny seems to get better and shift smoother as I use it.
Currently no starting aids, it popped right off, without ether or glow plugs, since those are deleted. Probably will need just a huff of ether, in the morning, when cold. But cranked over maybe 5 or 6 revolutions on first start, and fired right up! Was about 70-75 degrees Fahrenheit, but 40 in the morning, may need a huff.
A turbo will muffle the exhaust to an extent.Muffler I ordered is back ordered, so it is loud, not terrible for downpipe only.
-2 more for the Dodge!It’s lighter, by 1200 lbs, and most definitely faster, than my Dodge. Awesome sauce.
You can still take pictures even though it's assembled. We're simple folks here and we love pictures.It’s in my thread, but I need to update it. I should’ve taken more pictures.
That's good news.Tranny seems to get better and shift smoother as I use it.
Happy birthdayWell today after Carol got me home from my early morning out-patient kidney stent exchange surgery I decided to go work some more on my shop. Well that didn't work out so well...... Carol got to holloring at me, told me get in house & lay down!
Sooooo here I am wanting/needing work on my shop but not feeling like it, so I decided to turn Bessie around, park her there where she can look at & watch my shop all rest of the day, all nite, & maybe even into tomorrow morning!!!!!!~
That'll show'em!!!!
BTW tomorrow is a National Federal Holiday for everyone!!!! My 73rd Birthday!!!!!
Block heater probably would, ZIPTIESNBIASPLIES has what he calls spit swapping lines, so if I put the heavy duty precharged coolant in my Dodge, and hydraulic quick couplers on my heater hose, then I can pump 185* coolant into it, and then it should fire right up. I want to do that at some point.@KansasIDI what do you think your compression ratio is?
Do you plan to try and use a grid heater or always just a snort?
Would the block heater warm it enough in the winter to not need ether?
I honestly think the higher psi injectors, and higher flow IP, would help starting, especially the injectors…Block heater probably would, ZIPTIESNBIASPLIES has what he calls spit swapping lines, so if I put the heavy duty precharged coolant in my Dodge, and hydraulic quick couplers on my heater hose, then I can pump 185* coolant into it, and then it should fire right up. I want to do that at some point.
Thinkin on ether shot injection as a permanent solution. Might go with grid heater instead, undecided as of yet.
I… think… about 19.5:1, wouldn’t be higher. Lower perhaps. Cranks very fast, less resistance on the starter. Maybe that explains why it starts so good?![]()
