nelstomlinson
Gandalf, is this it?I'm just not finding the picture.
I found it here. It was by Biofarmer93.
But do you put the passenger side nut back in? In order for me to do that, the idle solenoid has to go...My wrench gets all three fairly easy.
Same with my wrench. No issues. It gets a little tight around the solenoid, but I haven't seen one that I couldn't get all three nuts loose.Yes, all three nuts. No problem.
Wait. What? What is this voodoo? Do you just mean you prefer not burning your hands on a fully warmed up engine or are running at 2000 RPMs right after starting it and setting the timing then? Details please.I have "made my own" but... Prefer to use the factory wrench. I do grind it just a bit. As for the fast idle solenoid I remove it for any adjustments and... I time my engines cold if possible. To time a cold engine you remove the rear power wire on top of the injection pump and the power wire to the fast idle solenoid if your leaving that on the pump.
Me. I prefer setting my timing early on a Sunday morning. Neighbors seem to prefer it too. They all come out to watch.
I hate it when I forget to do something that I said I would do, at least I finally remembered...I'll post a photo of my IP wrench when I get home after work...
No matter how I do it, I still have to remove high idle solenoid before I can get to passenger side IP nut...
How do you guys get around that?
