Sensors
Gotta-B-Ford
BOOTLEGGER
Lakeland,FL
94 idi w/ factory turbo was wondering what are the 3 sensors on the front of the engine,1is pass. side in head top side?,1 is on top of block by #2 cyl,and 1 is in dri side head on the lower side by cooler? and also when removing the main fuel feed line(from filter to i pump)there was some sort of plastic bushing pieses fallig out?:dunno
h2odrx
Anti-O
Coastal Neckville, NC
Passenger side is coolant tempature sensor it controls idle advance, top of block by #2 is for the temp gauge and the other is for the temp light, as for plastic was it black? if so it was the o-ring stuff? if not :dunno
Diesel JD
Gainesville, FL
If it was the rubber gasket on the IP fuel return or supply line, you should replace it. You can make your own from fuel injection rated 5/16" fuel hose, or you can get the right one at IH.
