jaluhn83
Pretty sure the lug pattern is different on the newer axles. Other than that likely spring perch, shock and yoke differences. Not impossible, but likely easier and cheaper to regear what you have.
Lug pattern was the same thru 1997Pretty sure the lug pattern is different on the newer axles. Other than that likely spring perch, shock and yoke differences. Not impossible, but likely easier and cheaper to regear what you have.
Sent from my SM-G960U using Tapatalk
howdy
i just bought a 1991 f-superduty to do a crew cab conversion not trying to steal this thread i am needing a front drive axle
We’re a patient bunch, would be happy to help you get started.well I'm new to this forum and I'm not good at this type of conversation and if i do i would like help when i screw up also i am slow at typing
That sounds like an expensive project to me.does anyone know about making a fuel tank to go in front of the axle and between the frame rails and around the drive shaft
