hawaiian808
Whiplash FTW
http://www.procharger.com/models.shtml
Ok soo im bored and pondering ideas again, i found a chart for a procharger Cent. type and would 1100 cfm be enough for our motors? im emailing them to see if i can get info for
boost vs rpm vs pulley size
just back to my dumb ideas to add a few ponies to the old gal![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
because i still think if you can with right pulley size make 10 psi off idle and 20 ( max) at 3000-3200 rpm then we will have zero lag issues and have best of both worlds.
my theroy is based on a kit made for a gasser,
this is how it works in my head
and i exaggerated the numbers to simplfy the idea
gas motor
idle 900-1000 rpms 8-10psi
max 5500 rpm 35-40 psi
6.9
idle 900-1000 8-10ps1
max 3000-3200 20-25 psi
if you run a system designed to run 40 psi at 5500 you can split that in half and get 20 psi, and with no way of over boosting it because our engines are limited in rpm?
yes i know the numbers are not exact or correct but does this idea hold water? the parasitic loss of a Cent, type charger is minimal in a gas engine i believe 5-9% so i could imagine with a diesel TQ it would be worth it??
feel free to flame away![thumbsup :thumbsup: :thumbsup:](/styles/default/xenforo/smilies/cool guy.gif)
gas motor
6.9
