3G is a very nice upgrade in the charging path as it simplifies things by removing an external regulator as well as a greater overall charge capacity.Having changed 4 alt and 34 regulators tells me there is something else causing failures here.
It's just that if there is a problem else ware, it does nothing to resolve that problem. Resolve the issue first, be it an ignition switch, poor ground due to corrosion, poor connections due to corrosion or what have you. Then once you have your electrical system bugs resolved, upgrade to the newer style 3G alternator and reap the rewards.
In now way am I an electrical specialist, I just happen to have installed car audio and other electronic gear in automobiles for about 3 years. Doing so you see all kinds of issues. Issues that come back to haunt you because you installed 5 - 10 grand of electrical components and now the car's electrical wont work correctly yet everything you did is flawless. Perhaps some bumped wiring that now issues with poor connections etc.
I learned to really scrutinize a vehicle and make suggestions to their owners, prior to going and doing large scale installs. Kids do not want to be told their car may have problems because it is an old POS or what have you.
In my experience, "GROUNDS" tend to be a real issue because there are many throughout the vehicle and the problem stems from different ground potentials because of the placement throughout the vehicle.
Second to that is overall general health of the vehicles electrical, has it been hacked to death by previous owners, are there scotch locks used to piggy back power off systems not designed for the extra load? (People Scotch locks are bad bad bad)
A stock system will last for years if maintained, and kept in good general working order. Our trucks are wonderful because of the lack of computers, and fancy smancy air bags, Anti lock brakes, and all that other wonderfully over installed factory stuff.
By checking each "arm" of the electrical system independently, you can work systematically through the entire vehicle, IE lights, (that means all of em, including dash and interior) Fuel system, switches, fuel solenoids, tank valves, ignition to which there is none other than GP and the IGN switch itself, starter, charge etc.
One system at a time keeps you focussed. I would start with removing non stock items from the equation then GP, and proceed as follows, starting include the ign switches in column, Charge, Fuel, lights, then work back to the non stock items one at a time.
I do hope this helps.
