I agree if you can get an IDI down to 18:1 compression you can make it do some awesome things. Couple problems though. No one makes pistons with that low of a CR for us, which means you're into custom slugs already, probably cost around $1000-1500 for them, second problem is I hear that the GM 6.5 has something different about it to make starting at that CR not such an "adventure" By the time you deal with all that the IDI loses its "cheapness" factor and becomes nearly as expensive as a PSD with some mods or a Cummins conversion. All that said, if I ever get the cash I will build just such a 6.9 and see what it does. In Florida 18:1 I should be able to get away with it.
Pistons aren't the only way to drop the CR. On a 6.2/6.5, every .010" of deck clearance nets you about 1 point of CR reduction. The 6.9/7.3 should be similar. So, to go from 21.5:1 to 18:1, you need to either drop the piston crown .035", or raise the head by that amount. Obviously you could mill the pistons - .035" isn't that much off of a piston with .500"+ crown thickness. Unfortunately, the desirable pistons for a turbo motor have hard anodized crowns, so you would have to have them re-anodized. Another simple option is to have the effective connecting rod length shortened by .035". This is easy for a machinist to do by offsetting either the big or small end bore.
Probably the simplest way is to call up Cometic and order .035" thicker head gaskets. Total cost: $250ish. Cummins guys have been using them with fairly high boost and they seem to hold up until you get to stupid boost levels, where you are forced to o-ring the block. That is how I would do it.
The 18:1 6.5's usually use 60G glow plugs (12V self-limiting type) and simply glow them longer before starting. Some of the guys have also added a Cummins intake heater to warm up the intake air during startup. Obviously, the only real requirement for these start mods are 2 REALLY good batteries
The main cost as far as I can tell is the IP. DB2's are only good for around 250HP or so. If you want more than that you would have to use the mechanical Stanadyne DB4, which is good for about 350HP or so. So, a guy would need to get a DB4 pump that rotates in the opposite direction as the GM DB4 and have it's delivery rate adjusted for your app. DB4's are spendy compared to DB2's, so for the guy looking for big power it is going to cost you...
