memphisrain
Hi all! I've been lurking for a long time and it is about time I start restoring my truck. However, I'm at a crossroads with regards to the motor and I would like some input from you guys that are obviously far more familiar with these engines than I. I apologize in advance for the rather long post, but I appreciate your input.
Here is the story:
As my sig says, I've got an '88 with a 7.3. I bought it used with 175,000 on it when Diesel was $0.99 a gallon (~9 yrs ago). I'm convinced now, after doing a fair amount of research, that the thing has never really run to its full potential. I have always had problems getting it to start without cranking for a long time when the temp was below 50 degrees or so. I have replaced the injection pump, glow plugs, and control module on it. It started better after these fixes, but still never really right. Having said all of that though, it has never ceased to be dead reliable for me and has always got me home.
At this point in time, I'm getting ready to restore the thing, because it has a lot of sentimental value due to it being my first vehicle and it has always been reliable. At this point, I know the motor needs injectors, IP, new glow plugs, and the heads need redone, due to blow by from what I've read is bad valve guides. When I get the heads off, I'll take a look at the cylinders to see what they look like, it may need a complete rebuild.
My goals for this truck is to get to start reliably, and increase hp on it. I eventually want to use this truck to go out west to pick up old cars and build hotrods out of them. So I envision eventually getting a trailer that I can haul two or three cars on at a time. I want the truck to be able to to run 70-75mph comfortably, and still have enough pass quickly (ie. I don't need a five mile run at it). Obviously the truck will be used for other things as well, but that is the max stress that I envision myself putting on it.
Here is where I would like your guys' input: Will an IDI with a turbo do this? I'm really unsure of what they are capable of, because I don't think mine has ever run completely right. I'm also trying to weigh the costs. I figure I'll have around a grand in just rebuilding the heads, a new IP, new injectors, and glow plugs. Then somewhere around 2 grand in a turbo kit. All of this is assuming the lower end is o.k. I can get a used Cummins for $1500 and the adapter and motor mounts for another grand and I can get around 300hp for very little money (from what I've read online) I'll be doing all of my own work, other than the machining, so labor costs don't really factor in. Am I off base on my costs? Is it risky putting a turbo on an engine with as many miles as mine has?
Please try and keep the whole brand loyalty thing out of this, as I'm just trying to find the most economical way to build this truck to meet my needs. Any and all input otherwise is appreciated.
Thanks for reading all of my ramblings,
mR
Here is the story:
mR
