MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,702
- Reaction score
- 142
After reading several accounts of roadside repairs, breakdowns, and crippling back home stories, it would make one
shy away from contemplating buying one of these trucks.
I could have it all wrong, but it seems like many of you only occasionally drive your "hobby" trucks and they only really get a test when the rallye comes along.
A truck is just like a horse; "you gotta ride 'em evah day".
If one uses his long distance truck also as his daily-driver, then he can find all of those lurking quirks and conquer them as they forewarn impending complications; and, if anything does happen to go amiss, usually it will occur within a few miles of the house = much more convenient than way out in nowhere.
Another issue I have noted is that many begin last-minute major transitions and finish them up five minutes before heading out; this will almost always bite you later.
Another pit-fall awaiting the occasionally driven truck is OLD TIRES.
They may have like-new tread and only five thousand miles on them, but an old tire is an old tire, especially if that tire is a steel-belted radial tire; steel-belted radials have a "safe" (if you can call a radial tire safe) life of FIVE YEARS and that fifth year is running on borrowed time.
Radial tires cannot abide sitting un-used for weeks at a time.
The tread takes a "set" and flat-spots where it is in contact with the ground/floor and this causes the adhesive to lose it's grip on the steel cord, thus setting things up for a separation; it may not happen right then, but is sure to happen as things have already been set in motion.
Of course, catastrophic failures can happen un-announced and at any time; but, all the little things can be addressed close to home and long before any long trips.
Carry on.
Carry on.
