Quick turbo question
SumKindaRanch
Michigan
Will a Banks, Hypermax, or modified stock turbo be best for our trucks? I plan on a 90cc pump rebuild and some stage 1 injectors.
For a 90cc pump, you can run it on a stock turbo setup without issue, but upgrading the turbo really allows you to utilize the full potential of it. Heres a video of a ride in a factory turbo idi with my 90cc pump, stage one injectors, 60-1/T350 upgraded stock turbo among other upgrades.
03wr250f
Hamilton/Montana
imo the stock factory turbo/ats 093 kit is the best for upgrading/building off with hypermax being the second best. and banks being the worst.
the factory turbo has parts availability as does the hypermax, the hypermax turbo sucks tho. So for the fuel you have planned you would have to upgrade to a different turbo.(if you dont you will more than likely fight high egt low boost especially with a trailer behind you because you will back out for egts and loose boost) the factory turbo also has lots of upgraded parts available such as the stage 1 drop in from idiperformance.com
the banks is hard to get parts for, and does not have very much you can upgrade.
a stock factory/ats 093 or a banks will do just dandy with a 90 cc pump tho
I dont care for them but they seem to work fine, two of the seven gauges got warrantied iirc during this project. Customer service was good and the parts arrived quickly.
rewbrooks50
Forney, TX
How's the quality of the glowshift stuff? Looks pretty cool. How did you do the white face gauges in the factory panel?
The glow shift MaxTow gauges are not recommended by most; but, they are working great for me. And, my wife thinks she is in the cockpit is a 747.
The white face on the original gauge panel are a stick-on decal. Can be purchased on line, like amazon. Matched my other gauges.
rewbrooks50
Forney, TX
I like that video! Oh that’s my rig.
Macrobb
North Idaho
Got your own video if it to post? I mean, it sounds cool, but it sure looked to me like he barely gave it any throttle. Find a good high speed road and just floor the sucker! Let her eat!
Think something like what I do @ 1:35:
I prefer to rag on my own vehicles
derjackistweg
Cologne/Germany
Is there any reason why you rate these 3 like that?
I don't think banks makes any bad turbo product in its range.
A non waste gate turbo is not a good idea for a 3k rpm engine.
I think, if not ******* a budget, ANY modern turbo will be a better idea. All above are 80ies technology.
Banks one, btw, is a Mitsubishi turbo, if this helps any source.
I don't think that he was saying that Banks products are bed, just that it's hard to upgrade them. There's at least two companies that make an upgrade kit for the ATS 093/Factory Turbo set ups. I believe that the upgraded turbos just bolt in place of the original one. That's why they are the best for upgrading.
m2rtin
