pto?
u2slow
bilge rat
Coastal BC
Very doubtful. Most PTOs do not swap despite the same bolt pattern.
You need to check the pto mfr's data for the unique gear size and pitch required to get the rpm you need.
lotzagoodstuff
Carmel, IN
Both of those should be a six bolt opening, but the drive gear, driven gear, arrangement and output may all need to be changed for your application. It’s not going to be a straight bolt on.
if you got a great deal on it and it’s red, a good Chelsea dealer might be able to help you set it up. If it’s blue, I wouldn’t touch it, but that’s just me.
kbenz
kannapolis, NC
Found a cheap dump truck. was wanting to use the hyd on my f350 and then build a dump trailer with the back half of the truck with the 12v pump currently on my truck. haven't gone to look at it yet
