PSD bumper vents in a 89 style bumper how to
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
Ok a lot of guys have been asking what it takes to put the 94-97 bumper vents in an 89 style bumper. So here it is.
Tools.
I used a grinder with a 4'' cut off wheel
The belt trim is the same size on the bumpers
First pull the bumper off, it's easyer to do this
now pull the license plate mount
Next I set the vents on the bumper to fined center and then cut belt trim so the vents would over hang about a half an inch
Then I marked out where i needed to cut with a sharpie then I cut it out with my grinder
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
Then i trimmed the tabs off the back of the vents and set them in to place
I used some small screws to hold it in place. I put them inside the vent holes so you can't see them
Now here it is
Have fun!!!
liddledoggie
bangor, mi
i did mine about the same way. i would paint or some way treat the cut edges to prevent rust streaks from running down the bumper. this needs to be done at least in michigan. looks nice. joe
I am thinking before I do the bumper mod, I might try this; Make a flat or slightly angled air deflector to hang down from the lower radiator support. There are 3 big holes there that possibly could be used to mount it with angle brackets. This would be the same thing most new cars use. They have all those rinky-**** decorative small grills, but they get away with it because most of them have a rubber-like air deflector that hangs down under the car and directs air up into the radiator.
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
I'm planing doing the same thing only i'm putting an intercooler down there:sly
Do your ears hurt? That had to be loud! LOL
