Project Jerry
Fuel tank straps painted up for re installation
Rear frame clearanced down to the bump stop so I had room to massage the exhaust and tank fitment
Amp harness is wired up and ready for when it gets here
chillman88
Central NY
Please take a couple extra shots whenever you get putting the front spring hangers in. I'm hoping to be doing the same soon.
Overload springs stops installed from the 03. Had to drill out some of the holes but pretty much a bolt on deal, after you strip prep paint and buy new hardware.
Added the extra hanger and the exhaust is sitting just where I want it
Tomorrow I’ve got a full free day to work on this, looking forward to making some real progress.
mu2bdriver
CT
This is really an awesome thread. Thanks for posting the progress.
I am loving that exhaust!
I was thinking it may be a bit over bearing with it being 5” but it’s growing on me, and it won’t be restriction even with a compound setup.
Happy to! Glad you’ve enjoyed it ;Sweet
Are the 4 holes in the back wall of cab for your amp?
The four holes in the back of the cab with the black grommets? Not quite sure what those are meant for but i didn’t put them there, all the wiring passes through under the cab next to the rear cab mount through a grommet
Rear tank is installed for the last time, new sending unit are in the tanks.
Pulled the stock filler necks and knocked out the stupid restrictors. Stripped them for paint
Xrf Ball joints are pressed in and axle is reassembled with all new seals
F-superduty springs swapped on
Pulled the radius arm (pretty sure that’s the wrong term) mount off a parts truck and transfered the bolt holes to paper the old school way.
Did a little reinforcement for the frame, no I’m not a welder but I’ve never had a weld break on me.
Cut the holes for front hangers, the rear three bolt holes are already there for the core support mount, so you line up the hanger with those holes and mark the other three to be drilled. Easy peasy
Stripped and painted the underside of the engine crossmember
Drilled the holes for the radius arm bracket
Radius arm bracket stripped and painted up
Pulled the shock mounts off the f-superduty, they may be too tall but I can always cut them down, well see once the axle is in
Painted the filler necks, I think the black will look nice inside the white filler doors.
chillman88
Central NY
I'm thinking that might be the track bar you're calling a radius arm?
Looking good so far! Everything looks better with fresh paint!
Haven’t decided on the firewall quite yet, but I do use dei heat wrap on all exhaust components, works very well
morerunner
