Does this look Welded to You?
divemaster5734
Olympia, Washington
Long ago, in a land far away, I foolishly believed I could buy my way to the vision I had for a truck I had just bought.
Armed with that woefully misguided arrogant assumption, I found a "professional" shop that had a con-artist and thief owner.
After many months and many thousands of dollars, I was left on the side of the road with my two sons waiting for a tow truck, very thankful I was able to put out the engine fire on our way back from fishing, which also the first use of the intended purpose for the build.
By then I had grown suspicious, and had the truck towed to my home.
The following week I discovered that shop had closed it's doors, the large multi-bay repair building was in foreclosure.
It was then some of the many allegations came out, hordes of other customer complaints surfaced, and I discovered several items that I had paid for repair/upgrade that had only been made to appear new parts were installed, when in fact the old parts had been wire brushed to look new under a brief casual glance.
I only mention this because they worked on every area of the engine, running gear, and suspension, and as I keep going deeper into this resto-mod I keep finding things they did that are beyond anyone with an ounce of integrity could ever even conceive.
It took 13 years before I had the time to undertake the work myself and start the diesel learning curve.
Fast forward to yesterday, I plan to complete the rest of the work,( axle swap, hydro brakes, exterior body seal, all remaining interior work)in my garage, which means I have to drive it about 17 miles from where it is.
The check out drive for the new engine and zf swap revealed a death wobble @40mph.
Hoping to save a $200 tow bill and not spend a lot of money on the old 10.25 axles that are going away, I took a look at the sway/steering stabilizers.
The shop did a 4" Superlift 1 ton kit install, and charged me for new 4" lift stabilizers.
The first picture is the passenger front.
I put less than 500 miles on the truck after the lift kit. There's obviously a couple more miles on those bushings than that.
Also, as you can see, the top of the bar end was broken, the brake was just inside of the outer sleeve.
Looking closer there appear to be poor welds connecting the upper to lower bushings.
A close up of the lower bushing, looks like a 12 year old forgot to prep or turn on the MIG gas.
Drivers side. The pieces are welded, but they look mushroomed out, perhaps from a hard landing?
I've never had it off road, and before last month, never even locked down the front axle.
It really doesn't matter anymore, other than I'm trying to grasp the depth of that shop's deceptions.
I can't wrap my head around sending a customer's vehicle out knowing there's a loss of control potential that could result in catastrophic results just to make an "easy" buck.
KansasIDI
I hate printers
Wilsey, KS
Unfortunately, it would seem that nothing they did… was actually any good at all. If they went to those lengths to do the job the complete opposite of right... Scummers. The world is full of them. It sucks.
I always inspect shop’s work. Always. Every detail. There’s a shop in my hometown that I have had decent luck with, but I still keep an eye on em.
The tire shop… well… I watch the entire process. Getting new tires takes me all day because I won’t leave. Have had some bad experience with them, mostly good but enough bad that I stay there and watch and criticize. I check torque before I leave, with their torque wrench and the boss of the place standing behind me. And once… hammering weights on an aluminum rim… with the stick ons right in front of the guy… I grabbed the hammer out of his hand and told him that for every hit he makes on the weight scratching the crap out of my rims… well… you get the idea…
It’s too easy to be taken advantage of in this world…
divemaster5734
Olympia, Washington
It would be easy for me to lay blame and hold a severe grudge, but the truth is it's my fault for not following up after the first couple minor fixes.
Was crazy busy running a electrical contracting firm, but that's no excuse.
I still feel bad for his mom, whom he talked into co-signing for the building and forking up the down.
Her hubby had passed, and it destroyed her finances and credit.
Got filled in several months later by a random chance encounter with a tow operator.
He said she had to sell her home and move into an apartment.
He was rumored to be operating out of her garage and was shut down by Everett code compliance.
But then, without all that, I wouldn't be here, and for that I'm thankful.
Anything to do with the stabilizer or another name for it is "sway bar" is not going to cause death wobble or anything else that serious. It's just there to keep the truck flatter when it goes around turns, helping the handling. On many trucks the sway bar was an option and part of a handling package. The only thing it would cause not being hooked up is more leaning in a turn.
So in other words, I would still be very cautious with your truck. You haven't found the real problem yet.
XOLATEM
Virginia... in the brambles
Armed with that woefully misguided arrogant assumption, I found a "professional".....
Yeah, 'professional'...
Two things come to mind when I read the first part of this...
A long time ago I had a pretty sharp guy come into my office to have me do some work for him...and he quizzed me at some point...with a ??..
"What is the definition of an 'expert'...?"
I had no clue where this was going....
(Answer)..."Someone who is 25 miles or more away from home.."
The other thing that came to mind just left...but it will come back...
But...one other thing that I would like to say is that You, Sir...weave a very good story...
Even though I hate to hear about people that think they are mechanics and present themselves as such and take advantage of good, honest, trusting people...I was captured and held for the duration until the bitter end...
And...I just hate to see crappy welding...and I am a hypocrite on this because I have turned out some welds that are uglier'n homemade sin...
But I have a collection of grinders and have had some formal training so I know if something will hold or is liable to break...
Back to the 'mechanic' topic...
If you find some of my earlier posts you will see that I am a stauch defender of good, talented, honest, hard-working and sometimes quality-of-life-sacrificing-for the sake of doing right by the customer mechanics...
Crap that you experienced makes it exponentially harder for honest mechanics to make a decent living...
'Sigh..'
Anyway...everything happens for a reason and it looks like things worked out so this site can get to know you and welcome you to the group.
And...you can continue on your learning curve and accomplish all you set out to do.
Good to have you here...and I hope that you have more stories to tell when you feel particularly inspired...no pressure...haha...
Clb
Another old truck
nannyfornia
On the subject of Death Wobble...
Do check the spring hanger and swing shackle bolts, are snug but not pinching the bushes.
Then the u bolts are torqued.
My rockcrawler will eat bushes due to some of the extreme angles and twisting of the rig offroad.
Once they get some wear, it'll shake the front on/in bumps or potholes...
divemaster5734
Olympia, Washington
Thanks much, will inspect ASAP.
I really wanted to drive it but due to the amount of time it's been sitting, even the "new" 35" tires are now around 14 years old, still holding air, which is really impressive, but not sure I'd trust them to hold with even a mild pot hole.
It's funny, because having it towed to the final restoration place is almost as bitter a pill as the breakdown, but then, I have a lot more time to dwell on stupid stuff these days...lol
u2slow
bilge rat
Coastal BC
After a 5-leaf spring pack install, the anti-sway bar is largely cosmetic. No one is going to lose control without it connected. (Took mine out; 95 f350.)
I wouldn't gauge the whole job on the end links.
divemaster5734
Olympia, Washington
True, but then I haven't gone into other things they did, among the more overtly dishonest, they wire brushed the calipers, and charged me for a brake job I never requested, declaring that the brakes froze up on a test drive, and when they tried installing the new pads the calipers froze.
I was charged for new pads and calipers.
After the fire I crawled underneath and realized they only polished the outside of the old brakes, they never even changed the pads.
That was only one other issue, there was one other that I filed a complaint with the WA auto repair board, but those guys are freaking clowns, doing nothing but sucking down public money.
It's embarrassing now, but I was a naive "mark".
They knew I was working 15-17 hours a day, 6-7 days a week, and used it to their advantage.
IDIBOBS
Southern California
I know it’s some what of an older post but man I’m sorry this happened to you. This is exactly why I became a mechanic and opened my own shop. No mechanic has ever touched any of my vehicles. 90% of them are ****. I did some contract work building early broncos for a company in chatsworth, ca. he wanted my shop to keep doing all the horrible things he was doing and just pay me less. I ended that relationship really fast. Glad it’s finally working out for you and your truck.
sramasya
