Thanks guys, I’m sorry for not updating the thread in a while, I’ll get some more pictures when I get back to the shop but here’s what I have from my phone.
Bilstein 5100s installed, on the bricknose chassis the shocks are forward facing, on the 03 axles they are rear facing since there is no rear tank, so I pulled the shock mounts off the axle swapped them side to side so they both face forward and cut off the detent so they are fully adjustable by loosing the u bolt and rotating them on the axle tube.
Bronco tank installed, I used the stock straps with longer bolts to drop it down 7.5”, didn’t need to modify the frame, dropped right in. I modified the tank straps to clear the exhaust, I’ve since made some changes to this setup for more clearance Clarence.
Got the ebrakes adjusted on each side and added a couple inches to the stock connector so it works like stock, didn’t have to change any of the cables this way and e brake works great.
