Got all the new silicone heater hoses plumbed with the coolant filter installed. I used about 10 one inch cushion loop clamps to secure and route the hoses the way I wanted them.
I finally figured out what fitting fits the inlet of the injection pump. It's 5/16 ORB for anyone wanting to know. I'm using a 5/16 ORB to 3/8 JIC 90 fitting.
You may have noticed I didn't use any shut off valves for my coolant filter. I carry these hose pinchers with me all of the time and didn't figure I needed valves making more clutter, cost, and plumbing. I can just pinch the hoses when I change it. An old piece of heater hose works great for any areas that the hoses will rub.
A big thanks to Junk for showing me that the NA CDR tube/grommet cuts down perfectly for the valve cover CDR grommet I was seeking. The left over piece of the tube that I cut off is perfect to fit over a 5/8 heater hose to protect it where it rubs.
